DC Offset - Preamp - Yamaha C4
Thanks guys, much appreciated.
Getting late here, so I'll have to pause for now.
If there's anything else you'd advise me to check or do just say and I can be getting on with it when I get started on it again.
Fair to say that a preamp with a 350mV DC offset reading shouldn't be awfully problematic?
The rising and falling makes me think that it may be a cap charging and discharging..
Could it equally be a transistor related problem.. and if so wouldn't freeze spray be a good way of revealing which component was contributing to this effect?
This entire thread concerns something of a non-issue. It is not right to call it offset as the preamp is entirely ac coupled. Whether the phono stage output is centered at zero or at 1v may have a tiny effect on the max output amplitude and distortion. Doubtful in the extreme if any measurements at normal operating levels can distinguish the difference.
