DC filament
I have build my tube amplifier this summer, I used kapton wire (very hard to twist..) so I skip the part of twisting wire... Now it`s intalled it induced a 60hz buzz... Can I use a rectifier and use DC circuit to heat my 6L6GC filament ? Thank
here's a trick to twist wire (even hard one)
hook the wire pair (or more) in-between a clamp and a drill's chuck.
Then use the drill !
hope this helps
PS: anyway, you can use DC to feed your filaments, but there's a lot of current needed in power tubes's filaments.
Anyway input tubes are more sensitive to filaments hum and use less power to run their filaments, that's why usualy DC supply of filaments is only done in the preamplifier.
Before going through the trouble of making a DC supply, make sure the filaments are the cause. Try the above advice. Failing that, try floating them +40V or so above ground with a voltage divider from the B+. If that fails too (usually doesn't), then you could go nuts on a DC supply...
