sasha said:Unfortunately two battery trick can't help because of changing resistance of the cell. Voltage needed for operating cell is ranging from
7V to 18V depending of electrolyte temp. and to have constant flow of hydrogen current needs to be constant.
Regards.
How much current do you need?
Use two batteries and make a constant current source out of a power transistor, a diode and a couple of resistors.
Here is a set of links to get you started.
http://www.discovercircuits.com/C/constant.htm
Phil
Hi guys,
Thanks for link, Haldor. I think I will find something useful on the site.
Have my eye on buck convertor and with some mods should be able to output 20A. Regarding suggestion for linear power supply,
two problems: 1. input voltage is limited to 12V (hydrogen gen. is installed on the truck) and 2. power dissipation is huge (24V in, 7V out
@ 20A = 340W )
Regards.
@ 20A = 340W )
Regards.
For a schematic, surf to the National Semiconductor website, www.national.com and go to the power section. Fill in the design requirements, and click "Create Schematic"
The design generator got a bit stuck on your amperage, but try to fill in some lower current requirements, and then beef it up a bit.
Bouke
Bouke
- General Interest
- Everything Else
- DC-DC step-up converter
