After many hours of hunting, I found some very basic specs on a set of drivers I'm intersted in.
BUT, they are quoting the sensitivity as 97 dB/W/0.5 M
So, is it possible to convert this to the more common dB/W/M ??
Even if someone can give me a vague idea of what they could come out as I'd be gratefull.
Doubt it matters but just in case;
The speakers are actually a set of car audio seperates.
Peerless P822000
Thanks......
Peerless P822000
Thanks......
er I think this is the relationship....
intensity varies as 1/R², where R is the distance in meters (or feet) from the source.
So:
1/.5²=1/.25=4
1/1²=1
so at .5 metres the intensity will be 4 X's as much at 1 metre.
and a power factor of 10 is needed to double the apparent loudness
what does this mean to you? At 1W@1m, you will be effectively lowering the sensitivity to 91dB.
stew
So:
1/.5²=1/.25=4
1/1²=1
stew
