• The Vendor's Bazaar forum is for commercial offers and transactions. Only unmoderated members can post here.
Dayton Audio PS220-8 Group Buy Offer
Special Offer Now On! $129.95NZD. Deal Activated when 10 or more units are purchased. Offer valid from 20/07/2011 to 1/08/2011.
Quantity Ordered so far: 0/10
Order here.
Dayton PS220-8 8" Point Source Full-Range Neo Driver - Description
The Dayton Audio PS Series drivers do it all: true bass, articulate midrange, and balanced, extended highs. An intensive program of design and testing has yielded full-range speakers that feature high sensitivity and smooth response, both on- and off-axis. Although an ideal match for lower powered Class A and Class T designs, the PS220-8 8" driver's superb resolution and natural sound quality make it a viable option for an even wider variety of applications. The PS Series' audio performance is complemented by the speaker's striking appearance—they look great in dipole and other open back designs, too!
Specifications:
*Power handling: 40 watts RMS/80 watts max
*VCdia: 1"
*Le: 0.75 mH
*Impedance: 8 ohms
*Re: 6.5 ohms
*Frequency range: 37-25,000 Hz
*Fs: 37 Hz
*SPL: 95.5 dB 1W/1m
*Vas: 4.64 cu. ft.
*Qms: 5.90
*Qes: 0.28
*Qts: 0.27
*Xmax: 4.3 mm
*Dimensions: A: 8.7", B: 7.2", C: 3.7".
High sensitivity/minimal distortion—an ideal match for lower powered amplifiers
Parasitic HF cone and carefully engineered phase plug extend on- and off-axis response
Solid bass performance, thanks to usefully high excursion capability (5 mm Xmax)
Optimized neodymium magnet provides high motor strength
Low-mass copper clad aluminum voice coil
Copper cap and copper ring on pole piece reduce inductance and distortion
Kevlar reinforced paper cone is lightweight yet rigid and well controlled
Cast frame with under spider venting for excellent cooling and low mechanical noise
Satin nickel spring-loaded terminals and brushed aluminum raised logo
