Dayton Audio iMM-6 False Response Rise from 200-20K
I'm very new to this world, but I recently installed a DSP for my car audio system.
I was noticing my LPFs were not showing reactions in REW when measured, but I could hear the difference.
I'm using a Dell laptop with a single headset jack, and set it to headset when plugged in.
I'm using the line out port on the imm-6 to send the audio to my HU.
Problem is, regardless of any audio signal or not, the microphone will report back a linear response from 200 to 20K.
If I unplug the line-out and use the laptop speaker (or when muted as well) the false response goes away.
Makes it really hard to tune here...
Any thoughts/help?
Can you do an electrical loopback test? Line out to line in first? This will verify the basic test system. Then I would try a test using a computer speaker to keep things really simple. Build slowly towards a full test so you can see which step it stops making sense.
I think the issue is my laptop drivers/software; some internal microphone calibration.
I found some Dell software that had a +20dB boost on the mic -- when I disabled that, the response dropped 20dB and now logs as a linear 20dB rise from 200Hz-20kHz instead of the 40dB rise seen in my screenshot.
