Hi all !
I tried to measure the voltage of the dats3 measurment sweep and im not sure if my voltmeter is overshooting cause the sweep is so short.
did/can anyone try to measure the voltage and can confirm my measurements ?
here are my results:
10dBu=2,415 Volt
8dBu=1,921 Volt
3dBu=1,079 Volt
2dBu=0,957 Volt
-5dBu=0,424 Volt
10dBu=2,415 Volt
8dBu=1,921 Volt
3dBu=1,079 Volt
2dBu=0,957 Volt
-5dBu=0,424 Volt
If you use "Generator Mode" the Output Signal is stable 😉
I've masured following values :
+ 12dBu = 3,083 V
+ 6 dBu = 1,544 V
0 dBu = 0,773 V
- 6 dBu = 0,387 V
- 12 dBu = 0,193 V
Exact what I expect, calulating dBu to Volt 🙂
BR Dirk
+ 12dBu = 3,083 V
+ 6 dBu = 1,544 V
0 dBu = 0,773 V
- 6 dBu = 0,387 V
- 12 dBu = 0,193 V
BR Dirk
@Dirk_S
thank you for the value.
i tried the generator mode, but ended with different voltage values for one dbu setting as there are different soundfiles. so i wasn't sure if this is compareable to the sine sweep of the measurement.
