Oh, yeah.
It does detailed analysis of resistors, caps and coils.
Also does full impedance plot of a driver in the cabinet (which you need for crossover simulation) as well as the finished speaker like you often see in Stereophile:
Which is a great troubleshooting tool. When you finish building a speaker, you compare your simulated crossover impedance to measured. This will often show bad parts or bad solder joints. If a speaker sounds odd, you can test the impedance to see if the two sides match.
Stuff like that.
Stuff like that.
