Data sheet for CSS WR125STR?
Hello. I had the good fortune of purchasing 8 CSS WR125STR drivers. Problem is: I can't find a data sheet with the T/S parameters . . . anywhere.
I even e-mailed CSS, but even they said they don't have them. I know you've designed a lot of cabinets with these drivers. Does anyone have a PDF they can post or send me?
WR125S sheet attached. WR125ST advertised values Fs: 65 Hz, Qms: 3.98, Qes: 0.77, Qts: 0.65, Vas: 5.8L, Sd: 57 cm^2, Xmax: 6mm one way, Re: 14.1 Ohms, Le: 0.65 mH, BL:5.7 N/A, Mms: 4.5 grams, SPL: 85.8 dB @ 1W, 1m, with the FR & distortion measurements stated as 'similar to the WR125S'. Dave's dimension sheet contains some also.
Reactions: RAW
