Daphile - Audiophile Music Server & Player OS
You can always contact Kipeta if problem still exists..
About new version..
There are pretty significant internal changes in audio decoding/transcoding/resampling area. Please report the problems with the test case details (audio formats, settings, etc...).
The DSD support on media server has also changed a bit and you should run the "Clear library and recan everything" to get it working properly again.
About new version..
You were right about "Clear library and recan everything". It Works now ... 😱
How about BruteFIR mode? It doesn't resample anything, right? Does it work OK?
