Daniel Hertz Levinson M1 wow
Well he designed a Hi Eff speaker kudos for that. THe edges around the drivers would seem prone to producing a lot of diffraction, the edges of the front baffle does have enough of a radius. The horn will probably a lot of HIM's. As others have said get a Geddes system or build your own correctly and save a lot of $$$$.
This seems like it would be an easy pair of speakers to clone. Does anyone recognize these drivers?
I would say it's pretty obvious that the trim rings are there to dress up the pro audio surround. I wonder if we are going to see this trickle down into reasonably priced speakers.
So for cost of $2000 in drivers/horns, maybe $200 in x-overs, $400 for the box, one could clone the M1? It is bi-amped so really only crossover is for tweeter horn and 12 in mid bass. Probably 1200 Hz? Does anyone know what the x-over point is? A budget version could probably be made with Eminence driver substitutes. Under $3k for the whole thing.
Yes, pretty much.
They've been mentioned in another thread including the actual driver list.
damn this world! 😀
Actually, I was serious but now that you say it, I recognize the faces - just did not expect politicians to be on a DIY forum post. So, basically it shows that the M1 is used by the elite who literally eat caviar and drive Bentley's. The $200k (?) turn table monstrosity made with solid irridium billets makes sense now. 🙂
