Damping material for Dallas 2 BLH
I'm embarking on building Dallas 2 BLHs, but the tricky part is that I'm in Azerbaijan where audio shops don't really exist - so everything has to be imported, usually from USA or perhaps UK and ideally from as few places as possible. I can't get anything in-country except plywood.
I'm looking for advice on what sound damping material to buy, how thick, how long and where to place it. I'm hoping to buy from Madisound because they have other bits and pieces - terminals and t-nuts/bolts etc.
As I understand, I need to line the cavity behind the FE206EN, plus around the two bends in the horn.
In the cavity, do I need to line with felt or fill with wadding, or both?
Wherever I need to line, Madisound has a choice of 1/4" wool felt or 1/8" felt
For wadding there's a choice of three, wool, polyester and "Acousta-Stuf"
Any advice on choices (or alternatives) gratefully received. I'm very conscious that once I close the box I can't do anything about the bends so I only really get one shot at importing the right materials.
Also...when filling the voids in the boxes with sand, I've seen a few comments about sealing it neatly, I was wondering whether candle wax might to the trick - melt, pour in the top 1cm or so, smooth off. Or I could use cement, but it'll be wet until it cures.
From what I remember the only thing you need is a small piece of wool felt just behind the speakers and nothing else. You can get away by using carpet underlay which can be found easier and for cheap in places where they sell...well...carpets🙂
As for filling the voids, in my BLH horns with Fostex Fe126En, I used kitty litter sand found again for cheap in any supermarket store.
