Dampening Material for My Loudspeaker?
There are 3 kinds of UltraTouch,
1/ The foil backed stuff you mention, i've not seen that.
UltraTouch 4 ft. x 6 ft. Radiant Barrier - 30000-11406 at The Home Depot
It is only 3/8". If the foil is facing the wall i don't see any issue except heat transfer
2/ a 1/2" felt with a very thin black cloth "lining" on the back. This is the stuff we use a lot of for lining vented boxes. The lining is an aid to gluing it to the box and scribing shapes with a felt pan. This isn't on the web site and Bob & i may have found a localized stash of new-old-stock. I just got 1 of the last 3 200' rolls (800 ft^2) the distrib had and it had a 2005 inspection code. Bob sells it in more diy-friendly quantity.
3/ 3 1/2" and 5 1/2" wll insultion, comes in bats like fiberglass insulation. We bought a bat of 3 1/2". We use it for volume fill (ir microTowers). This would be the choice for a sealed box Gary Pimm uses it in has Hartley Boffle like, open back boxes.
Bonded Logic - Natural Cotton Fiber Insulation
The stuff at Home Depot i was suggestion turns out to be something different, made od cellulouse. No idea about this.
Enuff people start going in and asking for #2 & 3, we may make a small dent. But the amount we use in a speaker compared to insulation a house...
dave
Home Depot has the denim type, but only in two inch thickness, and by mail only.
http://www.homedepot.com/Building-Materials-Insulation-Fiberglass-Free/h_d1/N-5yc1vZbvev/R-202709974/h_d2/ProductDisplay?langId=-1&storeId=10051&catalogId=10053
Never heard of cellulose in bats. Only loose fill.
some mechanism to convert mechanical energy into heat = resistance
The "spring" is what you are trying to damp with the resistance.
Yes, putting your finger on the spring will dampen its vibration.
So can we get away from this silliness that putting fluffy fiberglass is "damping" the cabinet vibration. It is not. It is absorbing sound and perhaps making the cabinet back volume "seem larger", but it is not (realistically) damping vibration of the cabinet.
That is why the OP was asked whether he actually meant "damping" or "absorbing". I realize that it is a pet peeve of mine, but why does everyone insist on calling anything and everything you do to a cabinet: "damping".
Adding fluffy fiberglass and gluing tiles to the panels are two very different things and meant to tackle very different problems.
The OP was asking about damping the insides of his speaker. By that I took it to mean damping the internal acoustical resonances rather than tackling any particular cabinet wall resonances. Certainly fiberglass and felt products are very good at damping internal acoustical resonances.
David S.
I would agree semantically with you, but adding fiberglass or a fill will absorb some of the acoustic energy and therefore prevent that absorbed energy from exciting the cabinet walls (or driver's cone) in the first place.
Wow, a lot of misunderstanding so far.
You can damp the cabinets or you can damp the air space. Mechanical or acoustic energy respectively to heat.
My take was that the OP was asking about air space damping.
Damping the air space has only a small effect on damping the cabinets as the acoustic energy falls with the square of the frequency and the air space dampings effectiveness decreases with frequency.
A spring is not a damper, it is an oscillator. It is the vibrating air in the box or the vibrating cabnet walls that we are trying to damp.
dave
dave
Yeah, but these are simply vocal monitors for a stage, not full range HiFi speakers. So, it really isn't that critical for the musician to get their job done. Just stuff it with fiberglass or poly.
