DAM meets nCore via LL
TNT
Joined 2003
Please check my schema for hooking up a Soerkris DAM dac (using L and R for one channel diff mode) to a Hypex nCore 400 amplifier using a Lundahl transformer. Reason for this is that I'm curious of the result of such a connection. Is it this simple or is it more to it? The Can/Core pin should it go to the Dac or the amp?
The windings are low resistance i.e. 50 ohm or so but I assume that the 100k of the nCore is transformed back to the primary so the DAM sees a much higher impedance?
Any other comments or suggestions appreciated :) - thanks!
  • nCore_DAM_LL.pdf
