loudspeakers!!
Hi everyone!!
please check this out !!!!!!!!!!
http://www.diyaudio.com/forums/showthread.php?s=&postid=483014#post483014
trading section LOUDSPEAKERS INDIA
thanks
arasuk
Hi everyone!!
thanks
arasuk
hi
hi,
I did advise a beyma subwoofer ,instead of a dainty .
the beyma subwoofers that we get are original enough ,ie .the drivers carry the same serial nos ,as that of the beyma site ,the t/s specs are correct and finally box design ideas are avaliable on the site .
The dainty after some time ,lose the magnetic power and you got to recharge them .The dainty replacement cones arent avaliable ,while you can get the beyma replacement cones.
hi,
dude i made 3 way active system and i took dainty speakers those are good quality for small money.singh trading company chenni(09791087373 )mr.gurunathan he is a seniar person.hi! i stay in bangalore does anybody have an idea where it is available in b'lore
if the drivers r decent Rs 850 for a 10" is pretty cheap!!
guru prasad
ph:9666678606
You get them in SP road...to be more precise check the below contact info..
The gentleman here knows about what he is selling and can also suggest you few other brands...i auditioned few and were amazing!! he even has AV equipments that i may hav not seen else where in bangalore.
http://www.rajdeepelectronics.com/contact_us.htm
RAJDEEP Electronics
NO 2 MUNISWAMAPPA LANE S.P ROAD
BANGALORE 560 002
KARNATAKA INDIA
(Nearest Landmark : Near Dharmaraya Temple, Nagarathpet )
Phone No: 0091-93428 42661 / 0091-80-41495358
RAJDEEP Electronics
BANGALORE 560 002
KARNATAKA INDIA
Rajdeep Electronics
RAJDEEP Electronics
BANGALORE 560 002
KARNATAKA INDIA
I visited the store recently after reading about them online, and was extremely satisfied with the results. Will definitely be going to them soon. Thanks for the info 🙂
Dainty Speakers Shop
Dainty Speakers are available in Bangalore with Pooja Electronics, Sadar Patrappa Road nearTown Hall Side end. Bangalore.
Can Anyone post The Thoele Parameters of Dainty 6" woofer SW 651 8 ohms ?
Sharat Deshpande.
Sharat Deshpande.
I got a Dainty woofer (PF0820B) having 8 inch dize, 50w RMS, 100w max, and 4to 6 ohlm impidence. These are the parameters written on the device itself, and I don't have the other details like Qts, Vas etc. So any of you are having these details required for the designing of the ported box, please be kind enough to share the same.
Greets!
Google is your friend 😉: Another plan for open baffles | Page 2 | HiFiVision.com
With a 1.07 Qts, open baffle [OB] is your best overall choice, otherwise heavily stuffed sealed or vented or EQ sealed with a Linkwitz-Riley Transform [LRT].
Note that this is a very old measurement, so if your drivers are either very old and just been in storage, then time has probably raised Qts and lowered Vas over time, which can be considerable with some driver's suspension design, to the point where usage won't loosen them up enough.
GM
GM
hi guys... can any one help me with TSP for DAINTY FR0824 please???
this driver is available with local supplier...but its so disappointing not to have TS parameters !!!
You don't need any TSP with this kind of a unit. As large as you can afford a sealed cabinet, well stuffed to prevent the Fs from rising as much as possible. These 200W units sell for a couple of bucks, why worry? 6" class into 20 litres, 8" into 50, 10" 100 litres and 12" into 150 litres of net volume as a rule of thumb.
- "Dainty" loudspeaker parameters.
