Dahlquist DQ-10 flashback
Hi thanks a lot for the valuable advice Not all 1" tweeters are built same way i understand And some can stand more current through the coil
I tend to like simple things But i feel like i am alone sometimes People prefer complex things Like in cooking
When meat is good it can be even raw and you get pleasure
Well...I'm vegetarian! But, doc, carrots are...crunch crunch...!
Were we talking about first orders in the other previous page? And about series connection, since the thread is about DQ-10...?!
I find it amusing since it's very easy & forgiving ( of possible errors). The rule that I learned is:
The midrange must be must more sensitive than the others, so you gotta find models in PA speakers or bigger Sd; the tweeter needs ferrofluid.
Since it needs only 1 coil and 1 cap.
3 speakers, yes, bass-midrange & tweeter
1 coil and 1 cap
yes!
Reactions: ginetto61
the dq10s have a series crossover if i am not wrong
something more unique than rare fwiu
why ?
thank you But i understand that my questions are not relevant to this thread You are right I will read threads on crossover design first
Strangely series crossovers dont have a great appeal for the audio community
I just paid $200 Canadian for a pair of Dahlquist DQ tens the speakers you’re comparing them to are $3700 US ?
If you found a fully functioning pair of DQ-10's for $200 great. How would I know what you paid? Maybe they are fully updated, and the guy died, and you got them at a bargain?
I'll go one better, the smaller BMR Philharmonic in kit form, with the flat pack, and upgraded film caps costs about $1750 and they will beat the DQ-10s I had with upgraded caps and a ribbon tweeter - which if you take the original list price, apply inflation since then, and the parts I added, would be well over $1750, and still that pair of DQ-10's could not beat the BMR Philharmonics properly assembled.
Now to your pair, have you tested the drivers individually? Do the woofer surrounds need replacement? Are the caps leaking or dried out? Do they test in range of their specs? Please let us know.
BTW, $100 CD in 1973 is $651.39 today, the DQ-10 debuted at $750 US, so the original price adjusted for inflation is well over either BMR.
As an aside on pp 189 in TAS (The Absolute Sound) Volume 1 Number 4 spring 1974, Dahlquist writes in his response to HP's review that the replacement for the CTS woofer used in the first run of 400 speakers will be made in house.
According to a second hand account from Joe the Service Manager at Regnar (Speaker Asylum) units 401-600 were made with the original Advent woofer. Then Dahlquist modified the design and the Masonite drivers were used thereafter.
So, my advice is, if you have serial numbers over 400, recone the woofers if at all possible. If not, get the regnars, or buy an OG used. On units under 400, get used ones or buy the Regnars's the discontinuity with the CTS blending into the mids isn't good. They go deeper, but are made of thicker material, and are slower, and might have a higher Q - although I didn't test that.
I saw a pair of DQ-10s on e-bay, and got a flashback.
I was a kid when I walked in a proper hi-fi store of the late 70s, and I asked the kind salesman if I could just listen for 10 mins to those great machines that they had on their window.
He smiled and switched some speakers driven by a walnut framed black and silver, floating turntable, connected to a small control unit with right and left volume controls and a hefty black amp. Wow! All was so nice, and then he switched to a weird pair of non box-like, curvy ones, with white grills and oak cheeks.
Those sounded so much more free than the others! They breathed somehow. I still recollect that moment.
Then I started collecting magazines and those things wore actually a Linn LP12, a DNM pre amp, and a powerful Mark Levinson amp, driving Infinity Kappa towers, Linn Isobariks, and Dahlquist DQ-10s in white gown.
Never saw them again since, not even as vintage in someone's hands. They must have not been really distributed in Greece back then. Maybe members of a small import of 'exotic' American models of that era.
Some American forum members must have lived with them or had many listens. Did they really work well? Was there any real science behind that ''phased array'' concept and 5(?) way crossover? Is anybody familiar about their acoustics idea of panels with drivers everywhere behind a grill?
Was that the best speaker in the room, or I just was so little and it was white and curvy?
Here is it with classic black grilles and many photos from one
ebay auction
There's a famous Blues Musician in Rhode Island, "Duke" Robilliard. https://en.wikipedia.org/wiki/Duke_Robillard
I am told that he still enjoys his original pair of DQ-10s.
I can't speak to whether "Science" supports Open Baffle designs. I think the question is pointless, because every loudspeaker design is a compromise, even if the only things being compromised are affordability or practicality.
Here's an example of a very large Open Baffle (from the midrange up) design: https://gr-research.com/product/nx-treme/
john
There are lots of modern DIY designs that crush the DQ10. FHXL with the right driver for instance… a build can be done for <$500.
dave
Yes, that's true and I'll have to check out the FHXL.
I think its the evocation of the past - desires to finally get the object in question, or pleasurable moments that one hopes to recapture keeps classic gear alive - same with watches, etc.
My question is the following
I have found a FR of the Philips midrange cone in another thread
https://files.diyaudio.com/forums/gallery/data/1935/medium/fr.jpg
It goes unbelievably flat up to almost 10kHz 😳😳😳
In the DQ10 if i am not wrong is cut at about 1kHz ?
Been a long time since I've been here. Let's see if I can figure out the forum software... I run a couple of owner support groups for the Dahlquist speakers and have been through far too much literature on them and discussions with the employees who designed and built them, so maybe I can help with some input on them.
So, that's not the same driver. The DQ-10 uses the Philips AD5060/W8, the woofer version. That appears to be the AD5060/M8 or it's counterpart with a backer chamber. None of them are the same driver. Philips had an odd model numbering system at the time where different drivers with different applications, but the same basic size format would share the initial set of numbers and what came after the "/" dictated the function; "W" for woofer, "M" for midrange, "SQ" for squawker, which was the version meant to be used higher up to 10kHz.
I have this picture saved for some reason.
Those were the stacking stands that Dahlquist sold for a brief period in 1977 when stacking was all the rage. They were well-received when demoed at the 1977 Summer CES, but seemed to have disappeared after. They're quite rare. I've only seen a few pairs come up.
I do not know if someone know better but the DQ 10 have a striking similarity to these
https://cdn.shopify.com/s/files/1/2197/6387/products/IMG_4867.jpg?v=1638753359
it could be that they were used as a reference for the sound ?
Jon Dahlquist was a huge fan of the Quad ESL-57. In fact, his home system before he designed his speakers consisted of a stacked set of ESL-57s with a supertweeter between them. (think the Mark Levinson HQD several years before it came to be.) He loved the sound, but disliked their dynamic limitations, their limited frequency response especially in the bass and, surprisingly, their dipole nature.
The speaker was designed circa 1969-1970. Back then they did have available .75" tweeters which could give you good dispersion up above the 14440 Hz max you get from a 1" but the power handling wasn't there. So Jon Dahlquist (JD) decided on a piezo for the top end up to 27k I believe, and i 1" dome under that. At that time there were no commercially available ribbon tweeters AFAIK.
I think he got very enamored of the 2.5" dome mid driver which had to be cut well over 500 hz and well under 6k. so now 3 drivers over 1k. While you could find a nice woofer like the Cizek 1 8" woofer that could play over 1k, the problem is with a 10" woofer there is going to be a lot of IM distortion in the higher range. So the xover was set at 400, and the 4" cone was added.
By the end of the run, JD did go to a cheap JVC ribbon and turned it into a 4 way, which is what I did per the available plan. It resulted in a much better treble - more natural and acoustically neutral IMO, not to mention faster with more detail like harmonics coming through better.
The tweeter in the DQ-10 was the Mikrofonbau (bought by Peerless after the Dahlquist entered production) HTL-1913 3/4" (19mm) poly dome. No 1" tweeter. The midrange was the Mikrofonbau MTL-37, a 1.5" (37mm) (not 2.5") textile dome and little brother to the MTL-44 that was modified and OEMed to Infinity for use in their Quantum series a few years later.
Dahlquist never used a "ribbon" neither a JVC nor the Technics/Panasonic EAS-10TH-400A single-ended planar tweeter that was popular at a time because there was a glut of them on the market in the early '80s when they let go of old stock. Those were all third party mods that were sold as upgrades to the DQ-10. The Mikrofonbau HTL-1913 and Motorola KSN-1001A combination was used until the DQ-10 ceased production in 1989.
An Advent 10” woofer, same as used in the original large Advent.
dave
Gefco. Gefco made the woofers for both the Advent and the Dahlquist. While the former can serve as a drop-in replacement, they were not the same. The Dahlquist version of the driver differs from the Advent woofer in the cone stiffening treatment (shellac in alcohol), surround glue and process (ambroid cement and heated press vs. heat activated cement) as well as the voice coil former material (phosphor bronze for greater thermal capacity and slight improvement in inductance control). In practice, the Dahlquist woofer could handle a bit more power (handy with how power hungry they are) and had better top end break-up behavior, but the latter was irrelevant in the Dahlquist designs. Ironic considering the Advent really could've used that performance as its cone enters break-up before the crossover point to the tweeter in all their two-way designs using it. (The New Advent did address some of that with its redesigned driver.)
Per my experience - just the first batch of DQ-10's Thru #380. Reportedly, Jon moved away from it because it didn't meld well with the rest of the drivers (too slow). Most of the DQ-10's shipped were of the later type - thinner paper, different magnets, and they did not go as deep. Perhaps Advent built them, but they were not the same as in Lg Walnut or Util Advents of the 1975-1980 period that I had my hands on.
The first 999 used the 10" CTS woofer. This is per the Dahlquist service documents and I've seen serial number 884 that still had the CTS woofer. The reason for the change of drivers was because there was a supply issue towards the end of 1973 that was hurting production ie the company was left waiting for over a month for the woofers from CTS to finish what they'd built to fill orders. That forced Jon to look at alternatives and found that the woofer Gefco was building for Advent worked as a replacement with minimal modification to the design and gained a little sensitivity out of it as well. (This along with a crossover change netted a 3dB increase in system sensitivity, so it was definitely something not to ignore.) This resulted in what was internally known as the DQ-10A and was marketed as such here and there reflecting the woofer part number changing from D-1 to D-1A. Had nothing to do with the drivers being "slow" as drivers being "slow" or "fast" is a bunch of audiophile nonsense unless you're talking about something with high voice coil inductance. Gefco continued to produce these drivers with no change (cones were the same, magnets were the same) for Dahlquist almost twenty years after Advent stopped using their version with the introduction of The New Advent Loudspeaker. Even the DQ-20i used them in the early '90s.
DQ10 is not an OB. None of the drivers radiate backwards.
dave
Thank you for pointing that out. It's a common misconception that even I was guilty of at one point. The woofer is sealed, the supertweeter is a horn, the midrange and tweeter are domes only the midbass/lower midrange is without an enclosure, but it intentionally has such a thick felt layer behind it to offer acoustic resistance as to ensure it does not behave in a dipole manner. Jon Dahlquist was actually strongly against dipole speakers. He felt they "wasted energy" (direct quote) and confused the stereo image. He felt it better to have poor dispersion than to have in-room reflections.
Thought I saw the DQ-20 mentioned somewhere. That was designed by Carl Marchisotto with input from Jon Dahlquist. It's not a dipole either, though it uses an aperiodic loading of the midrange. (Kind of surprising that he went on to finally use open baffles in his Alon/Nola designs. It's worth noting that Marchisotto actually did most of the crossover revision work on the DQ-10 including the big switchover for those post sn 4134, the mirror-imaging and the change to metallized polyester caps. In the end, the DQ-10 was as much his design as Jon's, though, Dahlquist did continue to offer design input as a consultant even after his wreck pushed him out of ownership. Iirc, it was the DQ-30i designed by Jeff Hammerstrom that was the last model he offered input on.
Great stuff. So HP in his watershed review in #1 Issue #4 was wrong when he said that the CTS woofer was stopped at #400. That review and that speaker was a splash in the "high end" that has scarcely been equaled or surpassed. Again, excellent!
I have a copy of the TAS review in my collection of literature here and took a moment to look through it again real quick. Though there is discussion of the new woofer by HP and Dahlquist, no mention is made of the serial number when the change over would occur. The number "400" only comes up in reference to the frequency of the crossover point between the woofer and the Philips driver.
Hi thank you for so much for your kind and very helpful advice
As I said before the dq10 were my first experience of 3d Soundstage
I was struck from the feeling of a sound coming from the space around and particularly behind the speakers
Call it love at first listening
From this my effort to understand what makes these speakers so special
And i have concluded that it is the xover design
To cut short i would like to simplify down to a 3 way increasing the range covered by the Philips
If the magic is in the xover the drivers that are good but nothing stellar could be even replaced with better one
Sad thing is that i can't understand how this xover works For me it's a mistery
I would like to see a simulation of it
I am pretty sure that phase response and impulse response should be very very good
Imho it's the xover that provides a sort of coherency similar to a single wide band driver
A masterpiece
Reactions: Diogenes
