Dac's for use with the Ncore Amps
I think most people on here with Ncores, have the need for a digital source of some type. Since the Ncores are so revealing, digital sources that might have sounded good with other amps, may not fare so well with the Ncore. So I think that if anybody has some useful information about a digital source, in any price range, that they have personally had positive or negative results with while pairing with the Ncores, would be a great benefit to the Ncore listening community. The Ncores are very high end amplifiers. And with out a equally high end source, their true potential is never revealed. I believe in matching all the components in the audio chain with components of similar quality. The end result is only as good as the weakest link.
Agreed. Used a Wadia 121 with my Ncores and found it to be a poor match. Moved to an 1yre QB-9, and am very happy (needs a preamp). I doubt anyone here will be surprised....
FWIW, I'm happy with the Matrix Mini-i and Ncore combo.
I attribute this to the AD1955 DAC chip which is a touch smoother and a bit less bright than some. I did have the vendor upgrade the opamp from OP275 to AD8599, but I did this before listening to the stock version so can't really say how great a change that made compared to stock.
If you can without soldering, or if your handy with soldering, try swapping the opamps with either the Burson audio hd's or DEXA discrete's. Made a massive difference on my Eastern Audio Minimax plus. The burson's are fuller and richer, while the DEXA's are sharper and more crystalline. The minmax plus uses 2 stages of opamps, so I mixed and matched both and felt I got the best results possible with the combination.
I'm considering trying out a EXAsound e20 DAC.
That that does look very nice. Let us know if you try it.
I shied away from ES9018 Sabre32 DAC's with the Ncore as I sometimes listen to lower quality material like Spotify, Pandora, etc and was worried about the synergy being too revealing or clinical. But I did that without really trying one with it first so would be curious to hear your impressions.
The way I see it, with extremely revealing components in your signal chain, with a computer as a source, you can always play around with dsp filtering options to add sweetness and warmth to lower quality recordings. If you play around enough with the various plugin filters available with the top players out there you can replicate the "house sound" of any of the more forgiving system combinations out there. Now the best part is you can take it away for the ultimate in performance when you happen to be listening to amazing sounding recordings. You can't go both ways when you have components with a signature "house sound" incorporated into them.
