I've read about how good DAC8043 is in multiplying mode as a volume control. I can't find anything about THD+N or similar metrics.
The thing that bothers me the most is +/-15v Vref (input) in the context of a single +5v supply rail. Does it work fine? Is it really better than PGA2320?
I've built a working prototype, but I have no proper instruments to measure it.
It sounds OK, but I think it can sound better. Nothing big, just have a feeling that it is not quite there. May be it is all in my head as I'm really skeptical about awesome distortion figures for +/-15v input on +5v power supply. Just thinking, that PGA23xx may be better as it specially designed just for this application and shows THD+N on the same level or better that "opamp-less" volume control ICs (MUSES72320, WM8818, DS1882) as least on paper
i think someone else here did this some years ago and had some good success.
if i find the link later, i'll post it.
i might be mis-remembering but i think he found some things to do to improve performance.
maybe LT1028 isn't best part for this application?
best regards,
mlloyd1
best regards,
mlloyd1
May be LT1028 is not the best part, but I trust it more than DAC8043.
Here is the post with THD plot: http://www.diyaudio.com/forums/anal...door-opamp-connection-wanted.html#post3477668
It would be interesting to see a similar plot for PGA23xx
Still I don't understand how does DAC8043 shows this good performance with +/-15v Vref on +5v power supply?
