I have a setup at the moment where I have an upgaded non os DAC inside the cd player. It's fed by I2S signal from servo/decoder IC. Now I'm in the point where I would like to make a proper PCB for it. But, as I also watch movies etc. and would like to use the same DAC I'd like to include SPDIF input to this setup.
Have any of you guys done something similar? The main point being to keep the I2S connection inside player but to add switchable SPDIF input with help of for example CS8412. What would be the best method to switch these signal. If I could program programmable logic then I quess that would be the way to go, but as I can't, is there any other solution you can suggest to me?
Ergo
Ergo
