132Db - Dual mono PCM1794,WM8805 + CS8421= XLR +Single +Low jitter
Hi,i have the schematics ,could someone combine and come up with this dac
WM8805 + CS8421 + PCM1794A in dual mono no IV stage,just the out resistors
Optical + S/Pdif
maybe youll add a usb Interface,please adapt and post schematics if interested
here are the 2 schematics needed
The file 1DepositFiles
Optical + S/Pdif
DAC done ,really nice,overlay camed out a bit scrambled,but all ok
Hi
i have the pcbs for this dac,contact me in PM if you need some
Overlay a bit scrambled and transistors should be soldered smd
You just need power, 1A 15-0-15
*3.16Volt XLR and single ended Output
132db Dac ,192khz 24bit ,receiver is the best around ,as the upscaller and DACs
PCB >>> 14cm*8cm
Hi
PCB >>> 14cm*8cm
