DAC-END 24 (AD1865 NOS DAC )
Did this mod- sounds really nice and has the added benefit of not needing a output stage - simplicity !!!!
Thanks jackm
It was really good news flocchini!
Now I am thinking adding 3rd or 4th chips in the stack to increase the S/N ratio and output current.
Do you think it is good idea based on the current power supply on the board?
You have a nice day!
I have received the DAC-End 24, it sounds really good.
Them I added 2nd AD1865 chip to the board on top of the 1st AD1865 chip making them paralelled, it sounds even better, it can drive my pre-amp directly without tube output stage.
Now I like DAC-END 24 better than my ESS9018 with output transformers.
QuangHao
Can the power supply support 3 AD1865 chips?
Can the power supply support 4 AD1865 chips?
The mod with 2 AD1865 chips sounds really nice to my ears and it is elegant without any needed output stage
Thank you
Bob
