Hello
I did found that text on the web ;
It's from http://www.diyparadiso.com/
Is it mean that if we would put a notch filter between the clock and the Dac, there would be less harmonics from the Dac output ?
Thank
Gaetan
study of this phenomenon , shows that the clock at 44,1Khz has subcarriers ( harmonics ) that modulate the signal :actually put in words : the whole audio band is duplicated around the carrier 44KHz above and beneath and this continues with every harmonic
Thank
Gaetan
