I also own this board, and also a few other versions, AK4396 etc, you will not regret it is a good buy and it sounds quite good. I put a tube buffer after the DAC and retain the opamp that comes with it. I have not modified the DAC.
I use Xmos driver for windows 7 the latest version from Minishow is V2.10. Unfortunately the latest version from DIYinHK's XMOS is V2.19 this version will not work with the above DAC.
Ttan98, as I did download different XMOS drivers. Unfortunately still doesn't work at this moment! Problem as I said in previous post with code 10 shown in device manager!
Can I share your driver? If you could, please send it to micarlton@hotmail.com
My AK4399 parallel being upgraded to 4x Elna 8200 and has OP627 and LM43910 to roll. My friend did mod tube buffer the same as you I believe and being arranged audition this weekend.
sent to your email address. this drivers works with the Xmos with AK4399 in a single board, your version is a dual AK4399 with no Xmos in a one board??
My board version is designed by Weiliang/China that's why the DIYinHK's Xmos driver does not work with this board.
I have 2hand minishow0328 es9018 with xmos (no cd or anything)
If I plug it in to win7 or win 8 machines driver installs automatically (xmos usb audio 2.0)
But driver has problem; code 10. I have tried downloading all kinds of drivers but they are not accepted; even with startup-option 7 (ignore signature)
Ebay item 141088296880
Upgraded Finished DAC Decoder ES9018 32bit 192kHz DAC Optical Coaxial USB | eBay
Any suggestions? Im getting desperate....
- Digital Source
- DAC AK4399 + XMOS on Ebay
