D3004/6600 burn in
The screws were too tight. They should not be loose, but not
torqued too much. Maybe when too tight it warps the motor
assy and causes some rubbing?
What a strange situation. The aluminum faceplate is 6 mm thick and
frankly I don't see how it could happen something like that. If it were
a thin plastic, positioned in an inadequately large rebate, then yes.
The Scan speak tweeter is more revealing than any old Dynaudio
tweeter filled with magnetic oil, but it is also more demanding on getting the filter right.
You've got it wrong.
The obvious impact of ferrofluid on tweeter performance shows
the Qms parameter which is lower in value than the ones without it
and the impedance peak is flattened to some degree, more or less.
This means that the overall response around Fs is lower in magnitude.
The typical vintage Dynaudio tweeter parameters show that the total Q
depends mostly on Qms. ( Dynaudio D28/2: Qms=0,71; Qes=0,97;
Qts=0,41)
If it had obvious restrictions in FR like the massive early roll-of or any
such FR aberations, then it could have been considered less revealling,
which was never the case.
A friend had this problem with 6600. I took the tweeters to test. One was fine the other sounded harsh, nasal, and showed Impedance plot aberrations. I took it apart to see if anything obviously wrong, nothing. I put it back together and the Impedance plot looked better. Weird. The only that thing changed was the screws. So I experimented with the tightening of the screws and found that too tight front faceplate screws caused the problem. I loosened the screws a little and the problem was gone. The screws were too tight. They should not be loose, but not torqued too much. Maybe when too tight it warps the motor assy and causes some rubbing?
thank you!
when i'll have the time i'll take a try
No one can make guesses about what is wrong with your filter unless you show us your measurements and tell us more about the design. The filter is far more about the design as a whole than just the tweeter in isolation. We've asked for more information a number of times and yet you do not provide us with anything.
Buying a different tweeter to sort out problems elsewhere is not a good idea.
With your crossover you are bringing in the 6600 to cover basically from 10kHz to 20kHz only. There is virtually nothing up that high other than a bit of 'sparkle' or 'air' you are not going to get harshness simply from stuff in that frequency range.
With the 6600 alone and your xover you are going to hit a rather low impedance minimum of around 2 ohms at 10kHz and with the midrange driver in parallel with it things could look even worse. This is not going to be easy for your amp to drive and could be giving it problems.
When I said before that the amplifier is 'faulty' I did not really mean that it was broken, simply that it is inadequate for the job that you want it to perform.
If the amplifier does have a problem being connected to loads as low as that, then this could easily cause harshness, as the signal being fed to the midrange driver (where harshness would actually originate in your design) would also be affected by the amps inability to cope with such a low impedance.
ok, thank you for clarify.
yes my speakers have imp load very low...so onkyo that has only two transistors for each channel became faulty.....the yamaha has four transistor for each channel
