D1 - JFET I/V Converter
Formerly "jh6you". R.I.P.
Joined 2006
Hi all,
I know we have another D1 I/V thread.
Just want to separate this as D1 "JFET" I/V. . .
I believe PaPa will encourage us with this.
I also invite all of your opinions, advices and contributions with
your own idea or design.
Including the two compensation caps, I am trying to apply the
original component values, except in the area around J310.
I am using J310 as I have many left-over behind my previous
JFET pre project, Krazy.
As you see, this is for the unbalanced output.
I might lower the rail voltages and accordingly scale down other values, later when I actually build.
Will this work. . . ? Thanks for any comment. . .
Ayo. . . :xeye:
Found one mis-print.
Corrected and marked it in red - i.e. reversed polarity of the electrolytic cap at the bottom.
As the reversed polarity causes unsafe explosion of the cap,
I would like to ask Audiofreak to remove the drawing in post#1.
Thanks.
Looking at the schematics it looks as if this DACchip has no I-out - I dont know if theres anything you can do..... My AD1865 has pins where you can tap the I signal and not send it to the internal opamps - looks like the 1732 does not give you this option.....
Cheers !
Hans
Babowana said:
To build this, I wanted to see inside of my CD-player
Hek! found that the output of DAC was voltage, not current :xeye:
What should I do? Still can go ahead?
buy some older Philips junk
I'm full of them 😉 even if some aren't in my place.....
it's time to have more than few CD players,isn't it?
except if you are in new technologies ,as DVD or something.....
btw-when you'll try toob susy?
Cheers !
Hans
Cheers!!! 😀
Will try to find one
Have number of CDs, no need DVD/SACD
Time not allow my thinking back to tubes
But who knows 😀
steenoe said:
Maybe what you need is a nice J-fet buffer, without the I/V conversion,
Steen🙂
Tube buffer after the PCM1732
Ah, the sound sour for me
Jfet/Mosfet buffer, good idea 😀
Thank you all
