Hi Guido... yes S/H and one DAC.
Was the phase shift ever audible ? causing an image shift.
Never tried the player, i just wanted it for the part. I still have it, should have a garage sale to get rid of lots of stuff....
Don't think it's audible, the delay is very small. Speakers are also not dead in the middle...
The metal bar is easy to remove, it's held by two plastic clips that simply slide out. There is a bit of neoprene sleeving on the end of each rail, to refit just press the rail down and push those clips back.
Don't know any sources of "new" good quality 12.4's now... loads of rubbish Chinese parts around.
Thanks Guido
I'll drop you a message when I change one just to double check it. I wanted a backup for the draw motor and band and servo etc.. I'll have a look around the net when I have some more free time.
The last place to have any genuine ones that I knew of was Donberg. You might be lucky, and if not the complete assembly then the pickup itself.
Drawer motors should never fail... belts are easy to get as a general spares item.
Spindle motors wear... the CDM12.4 has a little plastic spring under the platter to prevent the worn bearing "rattling" for want of better description. A dab of light grease (I know ) on the bearing on a new motor I find reduces detectable wear greatly... even after a few thousand hours use.
Sled motors should last indefinitely... it's the original grease that's the problem.
My machine was originally a Stage 6 and went back to Micromega in 1999 and had it's mech replaced. I have regreased it over the years using silicone grease, just the standard servisol stuff from maplin.
I bought the spare laser heads a few years back and they look to be the real deal, I was saving them for when my laser full goes, the odd skip I can live with. Like a mentioned the only real problem that needs looking at is the front panel buttons my open / close is quite bad now.
Swap the switch with one you don't use... Stage two has a double speed button etc... and use the remote to save wear and tear on them
I have one spare CDM12.4 pickup only... genuine one. The lasers last a long time.
I reckon on (honest) no audible skips per year, that's around 2 to 3 hours a day use. I removed and washed all the gears and rack and sparingly apply Electrolube "Special Plastics Grease"
Big problem with a lot of mechs... the platter isn't true running. Look at a disc edge on and rotate slowly. The platter on the Japanese 12.4 I am using is perfect... seen some rubbish Chinese stuff that are a mile out... and the pickups are rubbish too.
Yeah already thought of swaping switches, only can really get away with time and the old double speed button which does nothing when the player was converted to Drive 3 back in 1999.
In order of wear, Open/Close, Next, Prev, Play, Pause/stop.
I might try micromega see if they can sell me some switches
Worth a try. Also if you are prepared to trawl the catalogues you might come up with a replacement.
Bit like this from memory.
C & K | Relays, Switches and Indicators | Switches | Tactile/Keyboard Switches | Tactile |D6C90 F1 LFS
At the risk of breaking one, do they come apart easily to clean or soak in WD40 etc.
Here are the switches
Saw a complete sled on Donberg, any good or is it a knock off? Audio Spare CDM12.4 (CDM 12.4) - CDM12.4 / 05, 691.30354/CDI210 / 40...
Can't really tell about the pickup... all the markings in the picture look OK.
Send them an email and ask directly... are these Philips or not as there are so many poor replacements around.
That's what I did, and they said genuine Philips, although that was 18 months or so back.
Those switches are "tact" switches,
Be interesting to know what these are,
http://www.littlediode.com/componen...70ec5764&xid=069d57533161a483c75ac333cf518984
Just got one from donberg (47 notes including postage etc..), was more money but sounds like the real deal. I called the other place and he said they aren't the real deal See how it goes with the other one, at least if I stuff up fitting a new laser head then I have lots of spares now.
Now to get the switches and I'm golden
- Digital Source
- D/A input bit depth
