Cyrus Two only works when switched off!
It's not necessarily a bad cap. And there's hope that the output transistors haven't failed since you sometimes hear clear loud music.
First step is to confirm that protection has activated. If the amp were operating correctly there would be about 1.2V across C39 (lower left corner). If in protect mode, this voltage will be reduced to a few mV. Would you confirm?
Just confirming this volts across C39?
Next step is to disable protection circuit so that amp is forced to operate. There is some risk in doing this, but if you consistently hear clear loud audio when you cycle power, this is encouraging.
Don't put your speakers at risk. Test without speakers first. Put a resistor in series with them to limit applied power when you reconnect. Install a temporary short across R59; this will enable current source Q11 despite protection fault. Apply power but be quick to power down if there's smoke. If there's no drama, report DC on speaker terminals.
OK I have an update from the seller in an email sent a little while back. He mentioned using it with a PSX but it kept blowing fuses. When I purchased the amplifier I notice the fuses were inside but blown.
I gather from his email he was using the amplifier with the PSX and did not remove the fuses!!
Sounds tricky for me. I rather get it back to 100% with whatever the fault maybe
-everything looks fine!
I'll probably refer to components in the working channel for convenience, but please make the translation to the problem channel.
You can confirm resistance of R107A, R107B in circuit with power off. Probably OK. Other suspect parts would be Q37, Q35, R101, R99.
Another safe test you can perform is to install a short across C51. This disables the class AB compensation; you'll get crossover distortion but if there's no longer fault protection, the bias comp fall under suspicion.
I just compared both channels and they are identical. I also checked driver ransistors, all good!
Q37, Q35 is working channel and Q38, Q36 faulty channel. All measure same with diode tester
