Cyrus One
Hi hacknet,
Do you plan on doing more of this work?
What equipment do you have?
I can't help avoid bad things happening if you don't have some of the basic things to service properly. So you have to ask yourself if you should get some service gear, or send the amp for service. There is a reason the better servie techs are worth their weight in gold. And some of them are pretty heavy! 😉
-Chris
As well as replacing the drivers, it would be worth checking the base and emitter resistors of the drivers and output devices. The Cyrus 2 I repaired took out one of these.
Don't mess about putting in cheap outputs then getting it working then swapping them for better ones as you will only ruin the PCB, just power it safely in the first place. Use 100 ohm resistors instead of the fuses if you can't get use of a proper bench supply.
Input Cinch Sockets and Alps Input Selector Switch - where to order
For several user's I need new input selector swtiches, potentiometer and input sockets (also suited for Cyrus II resp. Cyrus TWO).
From where I can order this parts?
An other possibility it would be, to resolder such a switch and potentiometer from a used amp/receiver part from far-east (e. g. Kenwood).
Who know, in which of such models the same swtich type is in use?
And what is the right name in colloquial English for this kind of switch (I don't think "Rotary switch") ??
Thanks for advices.
MJE3055T is not really suitable as it would be running too close to its voltage rating. It is also low gain and slow.
The following are available from Farnell
PHE13009
ST13009
BUL89
If the two that are blown are both in the upper or lower half of one channel only, then you can replace just those. If there is one here and one there then you need to replace the whole lot.
Today I have get a humming Cyrus ONE (all caps was already replaced by Panasonic versions) due an interrupted 15R resistor "R121" between GND and chassis (go to the attachment - first three images).
The usual present parallel connected capacitor was not in use.
Sometimes by a high current flow blown this resistor.
What is the main reason therefore ?
Additional I note a bypass-cap on only one of the both 10mF/63V behind the rectifier (the cap between pos. rail and GND - go to the fourth image).
is there a special reason for that ?
The used output power devices for this quasi complementary output buffer stage are different for L+R - go to the images No 5-8. Which exact type from SGS-Thomson is behind the PT-7 ?
The fast recovery diodes for rectifier PFR852 (last image) - go to
PFR852 pdf, PFR852 description, PFR852 datasheets, PFR852 view ::: ALLDATASHEET :::
are genuine equipped with or not ?
Thank you for your information.
Sonic quality of this amp device is excellent in all respects.
The PT7 are supposed to be BUV28/BUV28A fast switching devices.
If you fit standard audio transistors the amp tends to sound dull and lifeless to me. I had a cyrus one with PT7 in one channel, and some generic linear parts in the other, the linear parts sounded rubbish. I have found parts like FJP13009 work better as replacements.
The Misson Cyrus amplifier designs 1,2 both used switching power transistors in quasi-complementary arrangement, as did other UK brands of the era, such as early Naim models, before the advent of Japanese developed, multi-emitter transistors which were both fast and more linear. Cyrus 3 used intermediate audio power transistors 2SD1047/B817 as per Rotel.
The speed of switching was always considered important for reducing crossover distortion, which many would say is worse than asymmetric, such as quasi complementary output stages which tend to generate even rather than odd harmonic distortion. Often, that type of distortion sounds pleasing to listeners but crossover distortion is never good.
