cutting speaker carpet around recessed driver holes
What is the best method to trim speaker carpet around recessed driver holes to get a reasonably clean fit?, i was planning to glue the hole lot on with contact adhesive then cut through with a stanley knife and go around the edges of the holes reasonably carefully, but i am wondering if there is a better mathod anyone would like to share..
The other option is to cut the recess just big enough to fit the driver and the carpet thickness. Trim the carpet just enough to 'tuck in' as the driver is fitted. Pretty much what David said, but using a conventional gasket.
Rob.
Attached is a macro photo of the job i did trimming the speaker carpet (changing blades every 12in or so for the recesses)
