cutting down from 8 ohm to 4 ohm
I would like to cut down from 8 Ohm to 4 ohm, an the reason would be:
My amplifier is technics A800 mk2, and the current speakers are visaton starlet, a project that I've recently done, with the help from previsious posts.
Booth speakers have 7.2 ohm measured with a digital multimeter (not eight like the original project, i've done the crossover slighty different)
I think that cuting to near 4 ohm, would not damage the amplifier, and the speakers would sound louder on this same amplifier.
The problem is that I've calculated on a paper several times the resistence, adding the crossover components resistance, and my value should be close to 2 ohm, not 7.2 with is measured.
My thinking was to lower the resistance by changing the mid from 8 ohm to a 4 ohm driver, based on the fact that in all 4 ohm systems, presented in visaton site, the bass and high frequences drivers have 8 ohm, and they use two 8 ohm mid in parale, after the crossover.
Why is not three 8 ohm speakers in paralel, have a total resistance of 2 ohm? What is the piece that is missing from my judgement?
"Why is not three 8 ohm speakers in paralel, have a total resistance of 2 ohm? What is the piece that is missing from my judgement?"
As DF says, there is a difference between DC resistance with a meter and the driver's IMPEDANCE over the frequency range of interest.
You may also be trying to be too precise! (8R)/3 = 2R6 by calculation. In the world of speakers and crossovers that is really quite close to 2R.
Unless I misunderstand your point ... It is a safe bet that your English is better than my Romanian!
