Noob here...I read the Noob posts and Searched for this but did not find anything.
I have 3 old overhead projectors. I was thinking of building a 7" LCD Projector. Is it ok to take the fresnels I already have and cut them down to size? Would it work?
Yes.
The plastic can be brittle; if you're using a jigsaw, clamp the edge you're cutting tightly between two boards and drizzle oil on the cut line. Use a fine blade. Even better, if you have access to a band saw, use it.
also make certain that you that you measure and use the exact center of your fresnel no matter what the finished size.
XXXXXXXXXX
XX000000XX
XX000000XX
XX000000XX
XXXXXXXXXX
X = area to be removed
Hope that makes sense 😉
XXXXXXXXXX
XX000000XX
XX000000XX
XX000000XX
XXXXXXXXXX
