Customizing LED wash light bar
I am considering ADJ Mega Bar 50RGB, compact 22 inch LED Light Bar model from American DJ. It has several light control modes, but its mostly have no direct relationship with the music, no direct relationship between light and spectrum of the audio signal. It support DMX protocol, but that's not what I want.
I have an Audio Color Organ DIY device that uses three filters to separate the audio signal into low, mid and high bands, which used to modulate the MOSFETs, the MOSFETs vary the brightness of the connected LEDs.
I want to know is it possible directly power the diodes on this Mega Bar use Color Organ output?
Have anybody tried to open device to see how LEDs are connected on the Megabar board?
I have not seen inside this particular bar but it is quite likely your plan would work, the LED board would be driven as 3 primary colors in varying intensities to achieve the range of colors offered so you would just have to bypass the OEM control board.
Yes, I am aware of "Sound active" mode. I just have no this board yet, so can't test it. But seems, this mode just reacts to the bass, no other algorithms is used.
Sound active mode on these things tends to result in a whole lot of strobing which is quite different than the type of results a classic color organ produces.
I have similar units. The leds on those bars are PWM controlled.
The PSU is usually 12V 3A. Each segment has 4 wires, or 8 wires (for 2 rows), so it should work. Some have the limiting resistors on the boards, others on the control board.
i guess i'm thinking old school color organ circuits that used triacs to vary "ac power" to strings of colored lamps are these led bars driven the same way?
Well, seems that may not be so simple as it appears, as these LED bars have LEDs divided into separate segments, and each segment controlled individually. I need manage all segments of the same color at once: not sure how they should be connected.
You could use a triac, but it must control DC low voltage. Perhaps a SCR or Mosfet instead of a triac, as triacs are intended for AC.
I need a similar circuit but 230V chaser to control 12V old school PAR 46 6V 5A lamps as I want to get rid of the bulky trafos inside them.
the electronic side is easy, I only need LED connection diagram, to see how LED chains are connected.
I have disassembled one similar yesterday because one segment connector was loose.
There are 2 4 wire connectors. Each PCB has 2 segments, so 4 PCBs. The leds are wired in series (one series for each color) and the limiting resistors are on the PCBs.
The problem is.. Leds aren't designed for reducing voltage dimming, I mean if You drop the voltage they tend to shift the color. There are voltage limits.
Get a bunch of leds wire them in series and hook it to Your color organ before modding the bar.
If it works well, just connect the segments in parallel. Assuming 8 segments with 10mA current, Your Organ needs to handle 80mA for each color, or wire them in series and use 8x voltage, but You have to change the PCBs since each color shares The common wire.
R-----Resistor----LED----LED-----| (didn't count hem)
G-----Resistor----LED----LED-----|
B-----Resistor----LED----LED-----|
Common---------------------------|
wouldn't PWM be needed to allow dimming on led's? most of the new Led fixtures i've seen seem to use PWM as the supply in order to achieve dimming and color change.
Depends on the internal circuitry in the LED bulb/fixture. Some LED bulbs dim just fine on an old analog phase control triac circuit, others do not. Some kind-of work. I got a bunch of colored PAR 38 LEDs to replace incandescents in my DJ lighting rig. They do dim, but rapid chasing modes do not work. If the AC is applied for too short a time they just won’t come on. Slower music activated chasing modes do work, as does the “power meter” mode. Strobing has mixed results - fAst strobing makes them come on full brightness, regardless of where the dimming control is set. I will eventually just build round PCBs full of LEDs in series parallel with a full wave rectifier and constant current source driver, but that’s a project for another year. Depending on what driver circuitry is in your light bar it may need to be completely rewired but could probably be made to work.
What I did find interesting is that the LED C9 retrofit Christmas light bulbs work perfectly on the original driver circuitry. They don’t quite dim down all the way when set to minimum conduction angle, but I think their response time to music signals is better than the old incandescent. No problems in color organ, chase, strobe or power meter modes. But those bulbs were intended for “animated displays”.
when i've played around with leds i've invariably found current to affect brightness and trying to accurately control voltage within the narrow/small range from turn on to max in order to achieve a brightness difference is far harder to implement.
i know Kvazar said he didn't care for Dmx but others may be interested in this MIDI to DMX - Control DMX Lighting with MIDI Keyboards or other MIDI Controllers
Thanks for useful info. How many sections in your LED light bar? Usually the sections can be controlled independently. If so, how they control individual sections if all LEDs are connected in series in the one chain?R-----Resistor----LED----LED-----| (didn't count hem)
- Live Sound
- PA Systems
- Customizing ADJ Mega Bar 50RGB
