This is a nCore mono chasis designed by James Romeyn. it has custom drill for a nC400 and a SMPS600. There's also a nice laser engraved nCore logo on the front face. The original post is HERE
Anybody interestes in it can contact James. We can manufacture and sell it under his permission.
Now the James Romeyn chassis is available for order under the permission of CEO of primeVibe James Romeny. It is designed for one NC400 and one SMPS600 modules. Beautiful nCore logo is laser engraved on the front panel under the permission of Hypex.
Here it is:
RE2207-JRNC James Romeyn nCore chassis
Here it is:
Interested
That looks great!
I would be interested to get two of them. How much do they cost with shipping to Germany? I would probably like to have a switch as part of the power socket to disconnect them when not in use for power saving reasons. Would that need a bigger hole for the power socket?
Best, sonnenwender
That looks great!
Best, sonnenwender
Just click the link in #4 post to order. It may take about $55 to Germany for 2pcs.
There's a IEC connector hole on the back plane, an IEC connector will be sent with the box. There's no power switch hole on the back but It's not difficult to drill a 10mm hole by any DIYer.
where does the NC400 sit?
Dear Siliconray,
one question before I order the beautiful case. From the holes on the drawing I presume that you have the power supply sitting at the back and the Ncore400 at the front. Now to me it seems wiser to have the NC sitting in the back, else you run the risk of picking up noise when passing the input or loudspeaker cables to the back via the power supply. Can you change that or is the case design flexible so that you can just turn the bottom plate the other way?
Dear Siliconray,
Dear Siliconray,
SMPS is at the front and NC400 is at the back. The glamour shots just show it backwards. The bottom panel can go either way so no worries.
See mine here http://www.audiocircle.com/index.php?topic=106187.msg1104426#msg1104426
See mine here Show Us Your Core-NCore!
Hi.. I like how your front and rear panel looks.. is that a custom one off?
-joe
- More Vendors...
- Siliconray Online Electronics Store
- Custom nCore mono chassis
