Do you folks have any information on creating a custom LCD panel. I do not care about the contrast. I recall many years ago seeing articles on how to do this.
Charles P. Lamb
Charles P. Lamb
Not impossible. Only extremely difficult. There are many good reasons that you pay upwards of a hundred dollars for a panel from manufacturers that can afford it by making millions of them.
You can make LCDs. You may even make colored ones. Making a panel with modern resolution and color depth is very very difficult. Unless you spend hundreds of millions of dollars on capital equipment.
custom panel
You could make your own single-pixel panel, for use as a controllable room divider or window shade. That would not be too hard. All you would need is glass with a super thin metallic coating, some of those glass spacers to keep the two sides apart a few thousandths of an inch, some LQ material, and two big sheets of polarized filter.
It would still be cheaper to buy it, though. And vertical blinds on a remote-control motor would cost 1/1000th as much.
