I have 90% finished Custom CD Player
Features:
Philips CDPro2 (VAU1254/11) Transport with Top Loading Mechanism
TDA1541A S1 Single Crown D-A Converter (Non-Over Sampling Design)
Custom Tube Output Stage using a 12AX7 Tubes for each channel (2 Pairs of NOS Tubes supplies 1 spare set)
Control Board & LED Display
2-1/2" Thick SOLID Acrylic Base
Solid Metal Machined Top Loading Lid
Custom Machined Structures (Sides/Transport Base etc)
Machined SS Pushbuttons & as well quality Gas Struts to hold up Top Loader
20 Blue LED's for Illuminating Pushbuttons
4 Transformers supplied including 120VAC + 120VAC for tube output stage); All Xformers are Dual Primaries so its good for Europe
7 Raw Power Supplies including Hi-Speed Power Diodes, Capacitors & PC Boards & Peg Boards/ Connectors (To Be Built)
3 ALW Tracking Regulators (For critical +/-5V & -15VDC for TDA-1541A IC) Already Built
2 - 317 Adjustable Regulator Power Supplies for +5/+5 Control & Diode Power Supplies
2 Raw PS for Tube Heater (10VDC & 300VDC for tubes)
3 RCA Jacks for Digital Out & Analog Out (from Tube Stage
All interconnect cables from CDPRO2 to DAC/DO/Control Board supplied
AC Power/Switch Fuse Module
Spare 1/8" thick plate if you want to customize rear connection panel
All Feet, Relay, PCB Standoffs, Connectors/Cables, Screws, electronic parts & other Miscellaneous parts to complete project are Supplied (98% of parts supplied with Player)
Complete Documentation & instructions to finish project
It is a beautifully machined CD Player designed & built by Anthony Tagg from Ancaster (DIY Audio Member Coulomb)
I picked up a Esoteric VRDS CD Player ... hence the sale of this well engineered CD Player & can be used as a Transport as well.
****SOLD to ROBB****
Features:
