current sensing for high voltage supply
sss said:
few amps @ 250V
Eva:
i can use sense resistor , but not with the ground lead , only with the Vcc lead 🙂
Why you can't insert a small shunt in the range of 0.025 ohm in the ground lead?
Also, have you considered using the Vcc lead as the ground for whatever control circuit you are employing?
its a bit complicated , had to do it for my work ...🙂
floating ground circuit is not an option also 🙂
Eva can u please answer my 2nd question in my other thread on this page , u are the only one who can 😀
peranders:
yes , i saw it , looks pretty cool , but its in a smd package
:bawling: hate 'em ! 🙂
