Maybe it would be easy to try using one of those clamp-on filters with the ferrite pieces removed from the plastic housing. Then winding the secondary is easy. Indeed, the concern is how delayed the response is.
Hello,
The downside of a current transformer is as analog was saying, changing wire resistance with temp.
I think it could be worth trying for lower powered amps though.
As far as the hall effect sensors are concerned their linearity and insensitivity to drift much over wide variations in temperature seem to make them an excellent candidate, the closed loop linear current sensors as Jaka has shown are said to be among the best type for linearity of ~0.1%, and bandwidths of 100Khz.
They appear to be nothing more than a very fancy current transformer.
I think both methods are worth trying, but for sensing actual output capacitor current, the hall sensor seems king.
Chris
Chris
Hi Chris,
tha fancy part of LEM current transducer is the Hall sensor and a little PCB containing opamp with discrete buffer. Current transformer itself is wound on laminated iron core, not even ferrite is used.
Problem with small ferrite current transformers is low frequency response. While 400kHz is reproduced faithfully, 50Hz does not go through and can easily saturate transformer. Temperature of winding is no problem since current transformer is a current source. But secondary winding must be designed for expected Volt second product and this is where core becomes large for low frequency response.
One possible technique I have never seen used is integrating inductor voltage. Differential integrator would have to be used and that is probably too much for opamp.
For capacitor current sensing I think that Fig. 19 from Carver patent that you linked is the way to go.
Best regards,
Jaka Racman
Best regards,
Jaka Racman
classd4sure said:
I've seen various other sense methods as well from patents which Mueta's reference, from Bose and Carver, mainly the Carver patent though.
http://v3.espacenet.com/origdoc?DB=EPODOC&IDX=WO0042702&F=0&QPN=US5606289&RPN=US5606289
Page 14 shows a few ways of sensing output cap current, one of which is your hall sensor. I loved the idea at first (found that one yesterday), but when I said quality could suffer I just didn't expect to strike gold first time out, I do want a full bandwidth audio amp though, which from what I've seen rules out hall effect sensors due to their limited bandwidth.
Rob Williamson (the inventor listed on the Carver patent) was a long time friend of mine. Sadly, he died suddenly and unexpectedly several years ago. He, I and several other friends had many a pleasant engineering discussion around my kitchen table. He was a valued technical sounding board and provided much encouragement that enabled me to work out my leapfrog design technique.
Active damping as outlined in the Carver patent does not look at or feed back dc current, but it is more-or-less a first order subset of the general leapfrog method (which provides the optimum control solution for any number of low pass ladder filter elements). I can't remember if it is written up in the patent, but I think Rob was the one who recognized that it is possible to look at output capacitor current by steering a small fraction through a much smaller parallel RC sense network.
For producing high fidelity audio, feedback signals must be virtually distortion free (after all, they are the standard to which feedback aspires). Quality voltage feedback is transparently obtained at the cost of a few resistors or maybe differential opamp. Too bad equally good current feedback (especially down to dc) is so problematic.
Regards -- analogspiceman
Hi Jaka 🙂
This seemingly clever idea suffers crippling distortion (eventually approaching disastrous proportions) as inductance falls off with increasing current. This sort of behavior is unacceptable for high fidelity audio feedback signals.
Hello, a couple of years ago I also had to build some circuits with a variant of current mode control.
Both Fets opened synchronously, the current was measured across R14 and R15. The resistors R16 through R19 removed common mode swing and doubled the measured output. Maybe, this is an idea for full bridges.
I also used current transformers for C-leg current sensing in a piezo-motor application at around 80kHz with very small ferrite cores, diameter was about 6mm from Epcos. Have to check the correct data, if interested.
Regards, Timo
Regards, Timo
Kenshin said:Some old, self-osc SMPS put the current sampleing resistor between output L and output C.
That sounds like a Mueta amp?!? Do you have any more information on that?
analogspiceman said:
I would be very cautious about trusting the integrity of a so called ground referenced current sense. My experience is that it is much better to sense "ground" referenced current differentially rather than try to star signal ground from a high current sense resistor. Your layout person will thank you. 🙂
Hello
Could you please give some hints about that?
I am planning the design with ground reference current sensing.
I thought to use a ground plane for power things and speaker return and take the ground directly out of current ense resistor (befor it connects to the plane) for a signal ground (input and modulator).
Is it the no-no situation you've mentioned here? Needless to say I am going to be my layout person.
Ragards,
Adam
PS. don't correct my misuse of articles please 🙂
Hello,
That subject seem to be an old inactive one.
I always thought that current was not usable for class D amplifiers for the reason that it carries the distorsion due to the varying output impedance. introducing the current in the feedback loop meant to introduce distorsion in the loop.
I have missed something ?
The biggest contributors to class D distortion are:
1. dead time distortion
2. inductor nonlinearities
which are both phenomena of distorted voltage caused by changing output current.
With current mode these two are virtually vanished even before you apply global negative voltage feedback.
Another thing is getting rid of a second order filter in a voltage loop and getting two first order loops: one current and one volatge loop.
Oh yes, simple measuring of the high frequency current (current around and after the filter cutoff frequency) is the key of close-loop amplifier. That's is for sure the reason why many used it (band pass current mode control, capacitive current Feedback, ouput voltage derivative...).
On the other hand, the low frequency current (before the filter cutoff frequency) namely the "audio band" current is much harder to measure.
But the point is: Since Load is unknown, audio band current is unknown.
To correct those low frequency distorsions, one might know the audio band current set point, no ?
Agreed, that's why it can work only with a lot of feedback in the audio band, which it easily enables. Win-win situation ain't that?
Another thing is cutoff short circuit protection for nearly free, much better than hiccup or shutdown modes.
- Class D
- current mode control
