Current limiting by the PCB coil, why not?
Chris, no, rather transformer yet.
The idea is: RM14 with usual coil inside, the flux closed inside also if core aren't saturated (<30A), and microcontroller see almost nothing from the PCB coil, which is placed under RM14 (very close). If current riched 30A and more, core of the RM14 saturated and will give strait flux outside, hence saturation process will be detected, as notable voltage increasing on the PCB coil..microcontroller shootdown etc.
