Current driven OPS?
...the OPS is current driven rather than driven by a V source...
BTW: what does this mean actually?
The OPS input impedance is changing so driving it with a current that is X times the input voltage signal is the goal?
Or you just mean it as the "output mode" of the VAS independent from the OPS load?
If so: a high current VAS and the it's output loaded to GND with a simple resistor isn't a good solution?
It's a matter of impedance.
And in this context these impedances mean dynamic, "delta" impedances, right?
Because of D7...
This is a simple current mirror as well.
Now - we can make it multiplying current, if we use emitter resistors with different values.
Providing a rather linear current gain.
And what makes this operation better and faster then amplifying voltage?
I mean at the input of the OPS high voltage (and so a voltage amplification at some point) is anavoidable.
What can be then the difference between a conventional voltage amplification and using current operations to achieve the same outcome?
Some examples of Current driven output stages
* Bipolar output stages :
- Wim de Jager, Erik van der Ven, Ed van Tuyl, ELECTRONICS WORLD, December 1999 pp. 982 – 987
- Blomley's amp as mentionned.
A handy program to merge Gannaji's PDF files is PDFsam (
http://www.pdfsam.org/download-pdfsam-basic/ (previous version at bottom right of the page)
PDFsam Enhanced (recent version, I have not tested it yet)
* Mosfet output stages :
- James Strickland's Transnova amps.
A further reference is Hawksford's "Error Correction and Non-Switching Power Amplifier Output Stages" (Preprint 4492, Presented at 102nd AES Convention, March 1997).
The paper eludes to suitable power transistors in a footnote and is interestingly framed within a similar desire to Blomley to engineer a non-switching output stage.
Some examples of Current driven output...
Thank you, the bipolar is new to me, I will read the article next trip to the library.
Are the authors associated with Technical University Delft?
It was some notes from a TUD course that was partly responsible to inspire this thread.
I have looked at the Transnova a while back but I will reexamine it.
Best wishes
David
Note that in Hawksford's 1981 report "Distortion Correction in Audio Power Amplifiers" he took (probably by mistake) some mathematical "liberties" that he later confessed to in his 1991 "Towards a Generalisation of Error Correction Amplifiers" as a result of negative feedback of another kind!
Funny.
Note that in Hawksford's 1981 report "Distortion Correction in Audio Power Amplifiers" he took (probably by mistake) some mathematical "liberties" that he later confessed to...
Special Thank you for that😉
I had noticed "issues" in Hawksford Error Correction but was hesitant to contradict a famous author until I had a very firm case.
I don't want to write a detailed critique if it's already old news.
Best wishes
David
