Current Conveyer Technology
Founder of XSA-Labs
Joined 2012
I ran across this Current Conveyer Technology and was wondering if someone has heard it in use and if so, any opinions on how well it works.
ACSS
attachment.php
It’s used in the NFB-1 headphone amp by GD Audio.
Lots of TO-92 transistors here:
It's basically two AD844's back-to-back, without the buffers, CCII current conveyor. If you buy a vintage Wadia D/A converter (or player) chances are there is a CCII as the post D/A current to voltage convertor similar to this, based on a PA630. Wadia called it the swift current conveyor.
Jan
Hi Dadod,
Maybe it’s time to pull the partially finished PCB out and populate it then. I did not realize it used this topology. My issue was that once I started assembling it, the sheer number of actives sort of threw me off. Nowadays with more experience under my belt it is not so daunting but I think an SMT implementation on the input and gain stage would be preferable (and faster to assemble).
X
Thank you jan.didden, xrk971!
Definitely not measure better. And sound is in the ear of the beholder 😎
Jan
True. The best result I was able to get is ~-93dB for second harmonic (@1kHz tone).
The main reason for switching to discrete implementation instead of ad844 is that the output current of ad1853 is too high for ad844 (even in the first version I've used 2 ad844 in parallel for each current output). And since this output stage was based on discrete components (well, except that matched pair transistors were used) and there is no control loop - I had to learn transistor matching technics a few years before I joined the ASIC design community 😀
