current bias j-fet input 2sk170 ,2sj74 at input stage
I design poweramp use j-fet input 2sk170 ,2sj74 cascode and current mirrow with 2sc2856 ,2sa1191 but idon't sure about current bias at input stage ,how much of current bias at input stage for high stability and performance if anybody know pls help
me
Same circuit
I'll be diesign 2Sk170 & 2SJ74 (2SK389 & 2SJ109) same you.
I think it's use about 2.5 mA with supply +/- 12V (after cascode)
You can use 2SK389 & 2SJ109 same me (I have a lot of 2SK389 & 2SJ109)
Mail me if you want some prototype
Regard
AHT 🙂
My humble advice:
There are 3 types of 2sj74/2sk147: GR, BL and V. This tells you how big the Idss will approx. be. Look in the data sheet:
http://www.semicon.toshiba.co.jp/docget.jsp?pid=2SJ74&lang=en
On page 2 you can see a curve called ID - VGS. From this I have concluded that one must have the signal as close to the top as possible to have minimal distorsion. And the smaller the signal is, the lower distorsion.
Unfortunately there are big differenties between the same types. One 2sj74 can measure Idss to 5 mA and the next 2sj74 can measure 10 mA. Therefore you must measure out all your fets and make sure they measure equal.
Onhttp://www.borbelyaudio.com/special_articles.asp you can read more about fets. In my opinion one should do this if one is not used to working with fets. Especially "The new Frontier" tells it all about bias and everything else.
amplifierguru said:
Hi Kanwar,
I don't think so, You would best use the K170/J74 with your 2N5551/5401 cascode to take it up to such heights.
Thanks Greg,
But I have seen somewhere in one of the professional amps using 2 series connected Cascodes i.e. total 3 JFET pairs in series ..... does it suffice or only adds distortion or add something else......
Secondly how do you came to know about that we are using 2N5551/5401 pair in our designs...🙂
amplifierguru said:
Hi Kanwar,
I think you should not be worrying over triple cascode.
Second, guru knows you use these devices, in a vision - and from an earlier post!
Hi GREG,
I would not use triple cascodes myself.......not at alllll........
Guru certainly has X-ray vision +++ HI-FI memory😉
