I am building a non os dac using cs8414 and pcm56. I was wondering if there are any other readily available IC's that do the job of the cs8414? Especially if they are dip. this is my first attempt at DIY DAC so any help is appreciated. I am really trying to do this design from scratch and I am learning all I can. Sorry if this has been asked before, I searched and could not find an answer.
Uh, I think he was refering to different chips, and not so much Aries adaptors.
But since the TI DIR170x series is kaput-ski, as are the '8412s, he does not have much choice. Without going to ASRCs and other stuff.............most of which are SMD.
Jocko
Jocko
There's that guy Tomas (Thomas?).. He sells CS8412 (and parallel TDA1541 DAC). I got 4 CS8412 from him.
I got some CS8412 from 3CAsia (I think!) - payed a lot!
They are all from different batch, but sound the same.
Unfortunately, my local supplier of TDA1541A (WES Electronics - Sydney) has run out of stock - no more TDA1541A. Shame, the price was very good!
Extreme_Boky
Extreme_Boky
I think he has 8414 as well.
Extreme_Boky
So this adapter would be suitable right?
http://cimarrontechnology.com/index.asp?PageAction=VIEWPROD&ProdID=6
So any hints on the best way to solder these tiny chips onto the adapters?
BeerCan said:So this adapter would be suitable right?
Yup. It is essentially the same as the Aries, though the brown dog has the second set of pads on the underside.
BeerCan said:So any hints on the best way to solder these tiny chips onto the adapters?
This chip is pretty easy to solder. With a small tip, you can solder each pin independently. There are other methods as well -- here are some tips. http://www.infidigm.net/articles/solder/
Are you having trouble finding a CS8414? Because I am!
Well, I suppose I haven't emailed Cirrus Logic for help, but I couldn't find one outside of those member only distributors of large quanities, one of which I found a company in China to sell me 2, sent the man a wire transfer, bank to bank only, of $80 ($100 total!), only to have him never to send the parts and change his email to steal the money.
But of course I'm pretty new to the DIY thing and am continually learning by mistake.
And why are most all those distributors only willing to sell by wire transfer?
Who is this Thomas? I still don't have one.
There is the newer CS8416..
hi!
you really need the cs8414?
i hv them and i also hv small adaptor pcb made, to convert soic to pdip pinouts.
problem is, i haven't bought those gold plated pins yet.
if you are interested, email me directly. i can only sell small quantities though.
donjuan
donjuan
Hey thanks! I just ordered one from newark.
I actually had tried them a few months ago, as directed by the Cirrus Logic webpage, but there were none in stock.
Sorry DonJuan.. I know nothing about you, and I don't mean to offend you, but you seem more like the Chinaman thief than the more sterile Newark. Your name doesn't help matters much either
please don't take offence.
I already have a BrownDog adapter.
I got mine at newark as suggested earlier. So I guess the consensus is that this is about the only chip of this type available at this time.
Thanks for the replies and suggestions
CS8414 daughterboard
Hello,
we sell 8414 daughterboards, look here:
http://www.audiotuning.de/1-53-digital.html
Regards.
Andreas
Hello,
Regards.
Andreas
coolness Andreas! I like YM-14-24 with the CS8414.
Is this a drop-in replacement for CS8414 in an Audio Note DAC?
CS-14-24, CS8414 special, is cool too, as are the precision clocks.
The YM-14-24 is a replacement for a YM3623 Yamaha receiver chip for example in an Audio Note DAC 1/2/3/4 only in conjunction with a 24bit digital interpolation filter.
YM-14-24 and CS-14-24 output wordlenght is fixed to 24 Bits.
- Digital Source
- cs8414 questions
