Thanks the digi01...😀
This is my first DAC board.
Use the CS8414 and CS43122.
Blance output OPA use the [BB] OPA 604.
And design the S/PDIF reclock in circuit.
Output the CS8414's all status[F0~F2...E0~E2]
Five single voltage power supply[digital and analog].
Two double voltage power supply[OP].
Very nice
(I only want to remind you that if you place these "hot" IC's in adapters you will get antennas = EMC emission, don't know though how much higher EMC you will get. The best you can do is to place fast IC's near the groundplane.)
