Hello everyone, my question - I am using a TDA 1543 based dac with a receiver 8412 which can not accept 24/96 flacs. If I am not mistaken CS 8414 is pin to pin compatible, so if I replace 8412 wih 8414 will it play 24/96 files ?
Thanks for replies ?
Hi, how would you do that? I have one of these boards
https://www.aliexpress.com/item/1005001614719053.html
Ok, you have seen the comment of the friend above - Attention: Replace the PLL filter resistor and capacitor. Will try and inform/
Cheers
Cheers
- Digital Source
- CS8412 replacement
