CS4398 evaluation board schematic - Values for R and C's marked with "NO POP"
I'm about to build a balanced output stage for a CS4398. Inevitably I came across the evaluation board schematic which is all intelligible, but I have no clue what the values for the resistor and capacitors marked with "NO POP" should be. Someone with a clue here? Can they simply be omitted?
It doesn't make sense to install a cap in parallel to a zero ohm resistor...
Ehm ... Obiviously!
The whole universe was created the last time someone made the laws of physics try to divide by zero.
Go for "transreal numbers":
BBC - Berkshire - Features - 1200-year-old problem 'easy'
