CS4398 dac with output transformers
I plan to modify a CS4398 based dac with output transformers in diferential mode. As you can see on the schematics, it appears that there's many ways to do that. Which one should be the best ? Any other recommendations ? Thanks
  • ciuff3_8.pdf
