Does anybody have any experience with that receiver ? I'm trying to get it work but with no results. Combined with CS84122. I use it in stand alone mode according to link below, check page 5:
http://www.apogeeddx.com/DS_EB_2000_2060.PDF
Any idea ?
Any idea ?
Hey there,
Yes, there is a stand alone mode (see page 5 of the data sheet here.
I'm in the middle of making a tenderloin roast, so I can't help too much right now...
I'm not familiar with that circuit implementation as shown in the link you provide - I printed it out, and will try to go over it tonight/tomorrow!
Good luck -
Good luck -
I don't have any experience with the receiver, but have experience with the companion part, the CS8405A transmitter. One thing I had trouble with initially was the reset line. I didn't think that the documentstion was real clear on it. Anyway. I believe the CS8405 is only active when this line is high. Check the 8415 datasheet and see if this is not also the case with the 8415. If it is and you are not somehow getting 5 volts to this pin, it's not going to work.
Who knows, it might actually be something as simple as that.
Stu
Stu
I suppose resert pin should be high because only then I have output from my dac. Unfortunately that output is not what I want. It seems to be like white noise through frequency bandwidth - it's like sound of the ocean but steady. I use simple CS4334 DAC, only 8 pins so no mistakes here. Checked power supply pins OK. Filter values after Cirrus errata so PLL should lock. There is one way to check about PLL, use out error pins 11 and 15 to see what they show but then no clue.
thomashek said:Does anybody have any experience with that receiver ? I'm trying to get it work but with no results. Combined with CS84122. I use it in stand alone mode according to link below, check page 5:
Any idea ?
The EMPH'pin is tied to +VDD which, according to the datasheet, means that the receiver enters the I2S 24bit data mode. Can you try to tie it to the ground and let us know what happens (this is supposed to put the 8415A into the Left Justified mode)?
Thanks.
--Andy
I have checked error output pins. They stay high all the time. No matter what I do. I tried nEMPH to low for left justified. Same noise.
Probably made some mistake in circuit or could be the DAC wrong ? I'm going to built receiver using another CS8415a chip and different DAC chip. I couldn't find any schematic on Crystal site for receiver in hardware mode. What I found out in CS8415a eval board datasheet was the same connections as in my circuit ! I just stick to that chip because I got them and CS43122 DAC chips via sample program. It was hard explaining in emails why, what and when but finally it did pay.
Any more ideas to make it work.
If someone of you give me the right connections "combination" and it's going to work I'm ready to send you one CS8415a receiver and one CS43122 DAC for free.
hi, i have experence in making cs8415 works.
hope i can help.
for pin 28, use a smaller value's resister, say 10k, 20k
pin 3 also the same as Pin 28.
the FLT pin must connect as in datasheet page 14, resistor use 3K...
but the most important thing is the reset pin, you need to hold "high" when power up, and then "low" for 200-500ms and then "High" ! its very trouble,
the reset sequence not same as CS8414!
hope i can help.
may be you can use a switch , cap and a resistor to do a mantual reset. if it work, you can add a reset ic (adm707/max707).
I cant got the chips via sample program, i have fill in all requirement in their sample program. but the chips i want havnt come!
is the sample cant come to HK????
HAHA ^o^
HAHA ^o^
takashi said:hi, i have experence in making cs8415 works.
hope i can help.
Do you mean that you need to hold the reset pin high for some time on power-up, before bringing down to do the reset? The datasheet's statement is quite different: "On initial power up, RST' must be held low until the power supply is stable...".
Thanks.
-- Andy
PS: I am making a dac based on cs8415a and cs43122, currently doing hand-routing of the PCB; so I am interested in all tips that would result in necessary changes in the schematics. I've used the CS datasheets for the design.
that's really interesting. I got some answers from people who said reset pin should stay high all the time. How did you find out that "pause" time. Any idea why receiver output the noise. I think when it doesn't lock or there is an error , it should be dead quiet.
yes, i tried to remove the reset circuit today, it dosnt work, i think the reset time(time for reset=0) is not enough. or there is another issue, i dont know, but but it work if i do this.
i just want to share my experience
takashi said:yes, i tried to remove the reset circuit today, it dosnt work, i think the reset time(time for reset=0) is not enough. or there is another issue, i dont know, but but it work if i do this.
The datasheet says that one needs to do the reset, I am not questioning that. I was just wondering
whether one needs to first assert the RST' pin high - which the datasheet seems to disagree with.
Thanks.
Takashi
I would be greatfull for schematic of your receiver with that reset circuit. I tried everything.
From what I can tell, the CS8405 and CS8415 have the same reset requirements. I designed a device with the CS8405 that uses a MAX809L to generate the reset and have had no problems. It keeps reset low until the supply reaches 4.63 volts and after 140ms takes the reset pin high.
Stu
Stu
maczrool:
i think we are at the same approch!
thomashek:
i have sent a circuit to your email , thomashek, because i dont know how to post *.jpg here. if you know, you can post here.
and i think use reset ic like adm707/708 will make the circuit more easy.
thomashek:
where to get CS8405 and CS8415 ?
does somebody know where I can get a CS8415 and a CS8405?
I ordered free samples at Cirrus many weeks ago but did not get any response. (May be they only deliver samples in the US?)
Can somebody help?
Boris (Germany)
Can somebody help?
Boris (Germany)
- Digital Source
- crystal CS8415 receiver
