Anyone wanting objective information rather than biased opinions will be well served to get their information here rather than at that website.
Planet 10 advocates it for speaker cables, try getting information about it out of him. 🙂
Yeah, he has some very strong opinions and I don't pay much attention to most of them. And there is certainly a commercial element to what is being said.
I think the coldest temperature treatment most of these supposedly "cryo-treated" audio cables ever experience is a few degrees Centigrade below freezing, during shipping to the consumer. If it's winter and the consumer lives somewhere cold-ish.
....you can appreciate the cold diode stuff. ...
Off-point but an interesting paper I just now found:
http://www.kennethkuhn.com/students/ee351/diode_characteristics.pdf
It was fun going through that paper, thanks for the link.
It is fun seeing the 1 nanoampere number being bandied about, I suspect my 3 inch diameter diodes are a tad more.
Really interesting is the vf vs temp dependence discussion and graph. I found out back in the 80's that 2.2 mV per degree C is wishful thinking. Typical diodes run .7 to 1 mV per degree C.
The reference to light sensitivity also brings back memories.....some of them good, others...well...
That was a rather well written piece for a student...wonder if he could use a job???
Jn
Jn
If anything, heat will remove stress in a metal that has been worked on, called tempering or annealing. You could call this 'let the atoms find their place in the lattice' if you want.
Some materials undergo a change in structure below a certain temp, and stay that way because the reverse process might take place above ambient. While I might expect a slight effect for brass instuments, conductivity is not changed permanently.
It would make sense to freeze MOSFETs while active though, google cryo-MOS. Current capability can be several times higher at -200C.
There is significant interest and effort in semiconductor operation at liquid nitrogen temperatures. I am not allowed to elaborate on that further, legal stuff.
Not crazy stuff, just IP.
Jn
Jn
Not sure its safe to have cables cryo-treated: the insulation wmay brittle fracture when well below the glass-transition temperature, causing cracking.
For actual cryogenic scientific apparatus they have to use special cables, often insulated with PTFE or polyimide which are usable at very low temperatures. (Incidentally copper is usually avoided for cryogenic use as it conducts heat into the experiment too well!)
Anyway cryo-treatment for audio is woo, I don't believe in woo. (Audio woo - RationalWiki)
If you want to harden tungsten carbide and steel cutting tools, its very useful, but other than that...
- Design & Build
- Construction Tips
- Cryogenic treatment
