Crunch GP 3000
Ok im working on this amp again after putting new + - 5 volt regulators in it.
Im running into the same problem again Amp powers up for a sec then goes straight into protection mode.
Heres what i have done to the amp.
I replaced both 5 volt regulators ( L7805 L7905) I put in a new KA78T12 regulator. I tested output driverboard in another amp and it seem to work fine.
Any ideas on where to start on this amp??
Heres a pic of the driverboard that was in the amp when i got it in for repair.
Other than checking for shorts or significant leakage, you can't definitively check regulators with a multimeter unless you have an identical (same manufacturer, possibly would have to be from the same batch) that's known to be good to compare it to.
The 78 'may' be defective since it reads essentially the same from 1-2 but that's only a guess.
