Crown XTI 6002
avif see my second posting on this june 2012 day: I clearly stated that my first measurements were wwrong by factor 2, since the signal generator showed only half the output voltage on its display (was set for 50 Ohm load but not loadad). So 1.3V would be the enough for full power.
Input clipping is >10Vpk. I could not reach this level with the signal generator.
Clip lights issue is still unresolved. since I do not run this amp at clip level, I don't care.
The reason I asked if you're clipping the Input is because the clip detection is done via a comperator, if the Input is clipped and the output is clipped then there's no difference so the LEDs won't light, no bug just a feature.
